-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   How to ID a VW trans and find a solid front mount... (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/252121-how-id-vw-trans-find-solid-front-mount.html)
Joe Bob 11-19-2005 01:08 PM
Looks like the front mount on the Speedster project has a torn rubber and it's the cause of the shudder and pop out....maybe.... of the trans in first and reverse.....
Anyone know where the ID # is on it? It's a four lug, 68-7x....or are they all the same?
Also, who makes solid mounts.....not like I care harsh it will be....
ejm914 11-19-2005 03:24 PM
early mount left... '73 and later on the right
http://forums.pelicanparts.com/uploa...1132442054.jpg
get both of them here
a solid mount will eventually break the nose of the tranny... what you need is something like this
Joe Bob 11-19-2005 03:49 PM
Looks like the one on the right. Thanks.
bryanf 11-23-2005 03:22 PM
back in my old type I days (20 yrs ago....ugh) we would use what we called "tranny straps" (probably same thing that ejm914 is recommending) that strapped the tranny to the mounting forks to prevent excessive movement (i think there were two--one by the bell housing, one at the front) they had arubber interface to the tranny so they weren't as harsh as solid mounts but did a nice job of keeping everything in place when abusing a type I tranny...
Joe Bob 11-23-2005 03:26 PM
yeah I remember them....I also used to use an angle iron,,,,,ran under the motor with allthread running up the fenders skirts......instant traction bars.
Conrad W Peden 11-24-2005 05:46 PM
trans strap top right... http://cat.cip1.com/catalog.asp?pg=110
I did the same till I went to the Super Diff with a 2010 Type 1.. then it was a hunk of channel under the motor
Joe Bob 11-25-2005 04:25 PM
OK...it showed, I got all the bolts off, disconnected the shift linkage loosened the rear tranny bolts....the big 22mm ones and tipped the rear of the engine up.
I was able to pry the old crappy, torn MADE IN ******* INDIA mount out....can't seem to tip the trans down low enuff to get the front three studs into the front nose cone while clearing the two front studs that point down......
Any hints?
rich 11-25-2005 05:21 PM
That's a VW bug. Check the Samba..
Joe Bob 11-25-2005 05:32 PM
Screw the Samba....somebody here has gotta have old timer memory...I know I DO....just can't remember what I forgot...
