Firewall Bushing Frustration
Okay - I am a believer - that bushing is uhhh difficult to install.
Can anyone relay a method or a tool that will work?
The old one came out in a few minutes. I gave up after several hours on the new one.
I read the tech article and may try the pipe pressure fit tool.
Frank
Old 10-26-2005, 09:06 PM
I have had great success by heating the bushing in a cup of water in microwave (get it to boil). Carefully take the cup to the garage, remove bushing with pliers, start it into the hole at an angle and whack it with a hammer. Sometimes after starting it at an angle you can pry it in place with a screwdriver. Getting it soft is the key.
Old 10-27-2005, 08:41 AM
914 Geek
Also, removing the rod that goes through the bushing helps. I even know people who have cut the bushing to make it easier to fit, but I don't think that's such a great idea.
Try hot water, as Jim said!
--DD
Old 10-27-2005, 08:48 AM
Hi,
I tried to soak it in boiling water for a few minutes. Better - but I did not get it in.
Will try the Micro-wave trick or let it sit in boiling water on the stove for a while.
Frank
Old 10-27-2005, 09:52 AM
Success!
The microwave trick worked great.
1. placed the bushing in a cup and heated it in the microwave under beverage.
2. I squeezed the bushing into an oval and placed the busing in the firewall at an angle. I pushed it in as far as I can go. Now this made a difference - I started inserting it at the bottom of the hole and worked my way around. The top was exposed and I used a 4 lb hammer to tap it in.
Thanks all for the suggestions!
Frank
Old 10-28-2005, 03:16 AM
I've discovered that a woodworker's hand screw clamp - the kind that has two threadded rods adjusting two wood jaws - works like a charm. Took me about 15 seconds to install the bushing. BTW, the same clamp works great for pressing the pistons of the brake caliper back in because the jaws can be adjusted to odd angles and still grip. However, it does take a slow, powerful turn of the screw do get the piston moving.
'00 Volvo S80
'96 Jeep Cherokee
'94 Toyota Camry
deceased '72 1.7
deceased '75 1.8
'41 HD Knucklehead (rebuilding basketcase into chopper)
'74 1.8 (Ravenna green and drivers still don't see me!)
Old 11-22-2005, 02:37 PM
SGB SGB is offline
SGB's Avatar
thats a great idea, I could see using such a device for many "soft clamp" situations. Where did you get such, Home Depot? Harbor Freight? A REAL hardware store?
-Scott
My gallery page
Old 11-22-2005, 08:23 PM
M. Hendrix's Avatar
Yep.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 11-22-2005, 11:22 PM
You can buy this clamp at virtually any hardware/home center and yes, Harbor Freight. Worth its weight in gold. I neglected to say that the shift rod does have to be withdrawn from the firewall, but that's the hard part of the whole operation. Offset the jaws so that one jaw grabs the lip at the bottom of the firewall, the other jaw squarely on the bushing. A few turns of the screw and you're done. Fifteen seconds - I swear.
'00 Volvo S80
'96 Jeep Cherokee
'94 Toyota Camry
deceased '72 1.7
deceased '75 1.8
Old 11-23-2005, 06:30 AM
grind weld build
sean_V8_914's Avatar
try a pc of all-thread and 2 large washers
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 11-24-2005, 07:49 PM
M. Hendrix's Avatar
I just put it on my nose, and bash my head on the firewall til it pops in.
Highly satisfying.
M
Old 11-24-2005, 08:01 PM
