Guess the part contest! Huge Prizes!
Ok well, its been a bit slow around here...
Its time to play guess the part! First to correctly guess gets the set of parts in 18-8 stainless steel! Ooooohhhhhh.....Ahhhhhhhh.... M4 Size Length 8mm with a 7mm Pitch. Most cars I have seen have 4 in the set. One had just 2 with the other 2 slightly longer. Where do they go? Shows one OEM and the stainless one. http://forums.pelicanparts.com/uploa...1134671202.jpg |
...and DD cant play because he is the sum of all knowledge 914...
screw that holds on rear rotor
Good guess! but those are longer...
I've got a guess. Mixing up the longer and shorter ones leads to really weird problems, right? (Guess how I know that...)
--DD |
Inside door handle screw?
Another solid guess.
The door handle is 900 147 004 02 an m5 screw gettin warmer... |
Rats, that was my guess! Hmm... M4? The ones of those that are coming to mind are slot-head screws, not phillips-head. Hrrr....
Let's see, phillips-head, M4, for a countersunk hole.... Hmmmmmmm.... --DD |
It's the screw that holds the trim around the inside door handle.
If its too long, it jams the handle. |
yeah but he said there are 4 in a 914....
window track screws?
VERY close goose2
gonna have to be a bit more specific. |
Lower dash cushion? Pete
Side mirror screws
!!! its the 2 window handle screws and the 2 inside door screws :)
bingo! |
I thought the mirror screws were larger than that. And there are more than 4 on a 914; there are two holding the mirror on (and may be two more on some cars), plus two more (I think) holding each of the door latches or strikers on. (Forget which at the moment.)
--DD |
The side mirror screws are much larger panheads.
914 531 523 10 Raised Head M6 x 12 Hint: You can only see two of them without a teardown. They are on the door. |
the ones on the bottom of the door, that adjust the top of the window in or out....
you know... |
Sorry...those are bolts and nuts
Thought this would be an easy one.
Does this help? http://forums.pelicanparts.com/uploa...1134757081.jpg |
Thescrews that hold on the front targa latches?
Nope, They are on the door.
trashcan.. I mean door pocket?
M |
Do they go into the thing that holds the window at the top of the track?
what year is that penny?
b |
window crank and door pull surround mount?
Door thingy....too long and the interior door handle doan worky...
Re: Guess the part contest! Huge Prizes!
i give up... spill it
They are the screws that hold the protective cap on the peak of the window. PART #8 http://www.pelicanparts.com/914/Parts/Body/front_door_window_big.htm I just hated that rusted screw mocking me. Stainless Steel baby! (insert obtuse Moby Dick reference) http://www.pelicanparts.com/support/smileys/loki5.gif Thanks for playin! Ive actually got a whole box o' these. :cool: To all who ventured a guess, just PM me your address for a set. I wuz wondering Mike ;) just kidding... -Rich Hilgersom |
1971 (S) Had to scrounge for the correct year. :rolleyes: |
Larry |
They hold the strike plate on to the door post. Two screws per strike plate.
| All times are GMT -8. The time now is 08:27 PM. |
