Guess the part contest! Huge Prizes!
Ok well, its been a bit slow around here...
Its time to play guess the part!
First to correctly guess gets the set of parts in 18-8 stainless steel!
Ooooohhhhhh.....Ahhhhhhhh....
M4 Size Length 8mm with a 7mm Pitch.
Most cars I have seen have 4 in the set. One had just 2 with the other 2 slightly longer.
Where do they go?
Shows one OEM and the stainless one.
Old 12-15-2005, 10:27 AM
...and DD cant play because he is the sum of all knowledge 914...
Old 12-15-2005, 10:29 AM
Conrad W Peden's Avatar
screw that holds on rear rotor
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 12-15-2005, 10:42 AM
Good guess! but those are longer...
Old 12-15-2005, 10:47 AM
914 Geek
I've got a guess. Mixing up the longer and shorter ones leads to really weird problems, right? (Guess how I know that...)
--DD
Old 12-15-2005, 10:49 AM
blitzer's Avatar
Inside door handle screw?
Old 12-15-2005, 02:50 PM
Another solid guess.
The door handle is 900 147 004 02 an m5 screw
gettin warmer...
Old 12-15-2005, 03:07 PM
914 Geek
Rats, that was my guess! Hmm... M4? The ones of those that are coming to mind are slot-head screws, not phillips-head. Hrrr....
Let's see, phillips-head, M4, for a countersunk hole.... Hmmmmmmm....
--DD
Old 12-15-2005, 03:16 PM
It's the screw that holds the trim around the inside door handle.
If its too long, it jams the handle.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 12-15-2005, 03:30 PM
bd1308's Avatar
Send a message via AIM to bd1308
yeah but he said there are 4 in a 914....
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 12-15-2005, 04:39 PM
window track screws?
"not an expert, but I play one on message boards"
Old 12-15-2005, 05:09 PM
VERY close goose2
gonna have to be a bit more specific.
Old 12-15-2005, 05:16 PM
Lower dash cushion? Pete
Old 12-15-2005, 06:34 PM
ws91420's Avatar
Send a message via AIM to ws91420 Send a message via Yahoo to ws91420
Side mirror screws
76 914 2.0 (critical condition)
73 914 1.7 (new project)
04 Pontiac Aztek (parts hauler)
Old 12-15-2005, 07:40 PM
bd1308's Avatar
!!! its the 2 window handle screws and the 2 inside door screws
Old 12-15-2005, 07:42 PM
Acox914's Avatar
Send a message via AIM to Acox914
Originally posted by ws91420
Side mirror screws
bingo!
-Aaron
"60% of the time, it works every time"
Old 12-15-2005, 08:38 PM
914 Geek
I thought the mirror screws were larger than that. And there are more than 4 on a 914; there are two holding the mirror on (and may be two more on some cars), plus two more (I think) holding each of the door latches or strikers on. (Forget which at the moment.)
--DD
Old 12-15-2005, 11:12 PM
The side mirror screws are much larger panheads.
914 531 523 10 Raised Head M6 x 12
Hint: You can only see two of them without a teardown.
They are on the door.
Old 12-16-2005, 09:12 AM
Acox914's Avatar
the ones on the bottom of the door, that adjust the top of the window in or out....
you know...
-Aaron
Old 12-16-2005, 09:39 AM
Wink
Sorry...those are bolts and nuts
Old 12-16-2005, 10:11 AM
