Trans wires???
ok... mabey this is a stupid question but, i have two wires sticking out of the side of my transmission on the driver side close to the starter... are they for an electronic speedo... or what are they for??
1974 914 2.0 |
reverse light switch
According to Google, "I" am Mike Mueller ![]() 1974 914 with 72 1.7 and 74 L-Jet system (vroom) |
oh.... well one of the wires is disconnected but my reverse lights still work???
nope....its literally a switch...those wires should have bullet ends on them...you'll see a sensor looking thing on the tranny...those bullets go in there.....
b
914 Geek
When you put the transmission into reverse, a pin pokes out of the guts of the trans into the switch. The switch shorts together the two pins, which completes a circuit sending power to the back-up lights.
With one pin disconnected, it won't work. If your backup lights come on, it's through some other mechanism. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
any idea where one might get those bullet ends, or what might work as a substitute?
Racer Girl 73 914 2.0 57 Vette (ok, actually dad's, but i get to play with it) |
You can get the connectors at Radio Shack. I think they are .18 or .23...
RETIRED
It also good to have a boot over it to cover the connections to keep crud out.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 12-19-2005 at 06:55 PM.. |
