golfguy9898's Avatar
oil leak help
I have oil pouring out of a hole next to the oil pump. is it a pressure relief valve? is it an oil galley plug that blew out ? its a 1.8 in a 73. I started it the other morning and it dumped all the oil on the ground. Ive had a few of these cars before and never had this problem. Anyone, anyone, little confused!!!
Old 01-03-2006, 09:53 PM
Control Group
Tobra's Avatar
Do you have a digital camera?
Old 01-04-2006, 07:01 AM
i'll take a photo and post it
Old 01-04-2006, 08:28 AM
OIL LEAK
LOOKS LIKE ITS NEXT TO THE OIL FILTER I FOUND ANOTHER CASE TO LOOK AT HERE ARE THE PICS. LOOKS LIKE A PLUG IS MISSING HOW DO I FIX THIS?
Old 01-04-2006, 10:18 AM
PICS
HERE THEY ARE
Old 01-04-2006, 10:39 AM
Old 01-04-2006, 10:43 AM
914 Geek
Oil gallery plug. Do not drive the car with one missing!!
If the plug is in place, but leaking, you may be able to use a "freeze plug epoxy" to help keep it in place. You will need to clean the living heck out of the surfaces in the area, so you will have to remove all of the bits that get in the way of access. (This may very well include the fan shroud!)
If the plug is gone, you might be able to find one that fits and epoxy it in as above. The preferred solution seems to be to thread the hole and screw a pipe plug into it. This runs the risk of getting metal shavings/chips into the oil system. So grease up the tap very well, and back it out and clean it off (and re-grease) every quarter-turn. It may also help to stuff the hole with a rag or with paper towels.
--DD
Old 01-04-2006, 11:24 AM
thanks dave
Old 01-04-2006, 08:33 PM
