scg scg is offline
scg's Avatar
-6 conversion mount/CIS/turbo valve cover q's
Okay, I've gone back through the posts from others who've done the six conversion, but I have a question about how to get the CIS on my 2.7 to fit without cutting the trunk. Here are the facts:
==> I have a Vellios bulkhead mount (purchased long ago -- I wish Richard Johnson had started earlier!). At least one post alluded to shaving the bottom of the piece that fits to the firewall a little before attaching and welding. Is this a good idea? Does it work? Won't that interfere with the fit in the top indent in the firewall?
==> On the "turbo" valve covers: how much metal needs to be machined off and where?
Thanks!
--> project update <--
Drilled the holes for the oil tank today -- drilling the bottom intake hole was a PITA, since I couldn't get my hole saw in there (thanks again, dremel!). It took longer to get a good looking result, but I managed. The test fit was *perfect* . . . now to buy a powerball ticket!
Scottt
2.7cis 914 getting closer all the time
Old 02-19-2001, 08:27 PM
Conrad W Peden's Avatar
I saw somewhere that people have put it in rotated 180 degrees(swap left for right) that may not be CIS though i just remember something of that nature popping up.
Just my two bits worth
CWP/VIR
72 914 L20E in rusto.
73 914 L20E 2.0L in resto.
http://members.rennlist.com/a914lover
Old 02-19-2001, 09:39 PM
914 Geek
Wayne got the 2.7 CIS motor installed in his 914 without any cutting. There is an article somewhere on the Pelican site that describes the process, but I don't know where it is. You can search around for it, or possibly ask him.
--DD
Old 02-19-2001, 10:11 PM
jabb's Avatar
I remeber reading something recently about being able to fit the CIS without cutting
the Trunk wall. not sure if it was here or
on Rennlist.com... I think there were
some changes required to some of the CIS
parts. Not familiar with the Velios mount...
Good Luck
Joe
Old 02-20-2001, 05:40 AM
scg scg is offline
scg's Avatar
Conrad: Yeah, I've heard that it works for carbs. I wonder . . .
Dave: I've searched, and darned and darned if I can find the beast! I'll email Wayne for help when I've got the motor in . . .
Joe: D'oh! I've got to join Rennlist!
Old 02-20-2001, 07:06 AM
Jim Smolka's Avatar
A 2.7 CIS motor will fit w/o having to cut the trunk. Email Wayne, he can send you pictures. Also, so of the FI lines have to me modified.
The FI lines for a my 3.0 CIS were alot easier to install.
For the Turbo covers, the top section near were the suspension bolts/nut for the trailing arm is needs to be ground. I am not sure how much. I believe it is the top two bolt holes towards the tranny When I need to remove the valve covers, I lower the engine a little.
Old 02-20-2001, 08:57 AM
si2t3m's Avatar
For the turbo valve covers go take a look in the 911 tech articles on this website.
You will see what need to be grinded off.
HTH
Marc-Andre Morin
70 914-6 conversion 2.2
Old 02-20-2001, 07:19 PM
scg scg is offline
scg's Avatar
Thanks, Marc-Andre Morin! I missed that somehow.
Old 02-21-2001, 01:57 PM
