Which Horn Is Which?
Pelican lists two horns for the 914. Hi & Lo tones. Mine, on the driver side, has stopped working. Which one is that?
Thanks |
If you can't hear it, it is probably an extremely lo tone. Sorry, if I hadn't said it, someone else would have. No serious answer for you. Good Luck
If the remaining one goes beep it is the high tone if it goes boop it is the low tone.
I also have no real answer except to say that try saying beep and boop and see how your horn sounds. or honk a honda and something else and see where yours is in relation.
999999999 1 4444 |
Good answer 914fan. I finally got them both off, and the working horn is stamped 400Hz and it does sound a lot like "beep". The dead one, OTOH, is stamped 335Hz. (interesting how much audible difference 65Hz makes)
Regards |
Another thing you can do....if your car has both horns, take them out and if you tap in the front with your finger nail, one will have a lower tone then the other. You will then know if it's the low or hi tone horn. Sometimes it's difficult to know if the 400megahertzs is lower or higher than the 300megahertzs cause (what the heck is a megahertz anyway).
Vern (disclaimer: I have no idea how to spell megahertz) |
I tried my horn today. I have only one, on the pass. side, and it was definitely an E. So the 335 Hz must be on the pass side.
1974 914 2.0 1980 911 SC 2002 996 Cabrio 2000 Silverado 2011 Golf |
I can differentiate pitch change to within .25 cents, that's 400 divisions between notes. I rock!
I can transcribe music as it plays too... as of 20 years ago.. That's a horse I fell off of a LONG time ago. ![]() M
I wish I had a dime for every penny I ever had. http://www.914club.com/bbs2/uploads/blog-1136350347.jpg |
