Which Horn Is Which?
Pelican lists two horns for the 914. Hi & Lo tones. Mine, on the driver side, has stopped working. Which one is that?
Old 01-26-2006, 10:40 AM
If you can't hear it, it is probably an extremely lo tone. Sorry, if I hadn't said it, someone else would have. No serious answer for you. Good Luck
Old 01-26-2006, 04:20 PM
914fan's Avatar
If the remaining one goes beep it is the high tone if it goes boop it is the low tone.
I also have no real answer except to say that try saying beep and boop and see how your horn sounds. or honk a honda and something else and see where yours is in relation.
Old 01-27-2006, 03:02 PM
Good answer 914fan. I finally got them both off, and the working horn is stamped 400Hz and it does sound a lot like "beep". The dead one, OTOH, is stamped 335Hz. (interesting how much audible difference 65Hz makes)
Regards
Old 01-27-2006, 04:25 PM
Rrrockhound's Avatar
Makes sense. 400 Hz is about a G and 335 is about an E.
Old 01-27-2006, 07:20 PM
Another thing you can do....if your car has both horns, take them out and if you tap in the front with your finger nail, one will have a lower tone then the other. You will then know if it's the low or hi tone horn. Sometimes it's difficult to know if the 400megahertzs is lower or higher than the 300megahertzs cause (what the heck is a megahertz anyway).
Vern
(disclaimer: I have no idea how to spell megahertz)
Old 01-28-2006, 11:07 AM
I tried my horn today. I have only one, on the pass. side, and it was definitely an E. So the 335 Hz must be on the pass side.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 01-28-2006, 03:30 PM
Me neither, but I know this: Megahurts means it hurts really bad!
Old 01-28-2006, 04:05 PM
M. Hendrix's Avatar
I can differentiate pitch change to within .25 cents, that's 400 divisions between notes. I rock!
I can transcribe music as it plays too... as of 20 years ago..
That's a horse I fell off of a LONG time ago.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 01-29-2006, 11:35 PM
