Post 914 roll bar trim removal
I am trying to remove the long chrome trim piece on the back of the rollbar (the piece that is the width of the rollbar and about 1/2" tall). What is holding it on?
Old 03-07-2001, 10:39 AM
HMeeder's Avatar
Post
Brett:
The strip is held in place by clips that are probably quite rusted. Very carefully work one end of the strip outward with a screwdriver and once you get it past the rollbar upright, you can slide the bar off the rollbar. I believe that is what I did 5 months ago. This is one of those cases where you can use gentle force if I remember right.
Good luck!
Herb
'72 1.7 Tangerine 'Teen
'74 2.0 Red Rustmobile
Old 03-07-2001, 05:19 PM
Smile
That worked! I sprayed a little lube in there too and that helped too. There were three clips. I needed to give it a bit more of a tug than what I thought was necessary.
Old 03-08-2001, 09:25 PM
