Steve F's Avatar
Question Is this correct??
Is this right? The 2.0 was only produced from
1972 on, and cases are marked with "G XXXXX"
Thanks everyone, I want to be sure I'm shopping for the correct engine.
Old 03-13-2001, 10:40 AM
Post
Hey Steve,
Not sure about what year the 2.0L started, I thought it was '73 (don't quote me on that), however all three of my 2.0L engines start with GA XXXXX, and it's located on the block just forward of the oil fill/breather box. Hope this helps somewhat.
Kevin
Old 03-13-2001, 11:06 AM
Steve F's Avatar
Talking
Thanks Kevin,That's a lot of help.You don't
need all those engines do you?Why don't you ship 1 off to me and I'll buy you some beer!!
Old 03-13-2001, 11:32 AM
Conrad W Peden's Avatar
Post
There is also a GB XXXXX engine. This one is the 95/100 HP 2.0L engine. I think its from the '74 LE.
Old 03-13-2001, 12:11 PM
914 Geek
Porsche Crest
The "GA" engine is the US-spec 2.0 (73-74), 95 DIN HP.
The "GB" engine is the European-spec 2.0, 100 DIN HP.
The "GC" engine is the US-spec 2.0 (75-76), 88 DIN HP.
All of this info is in the 914 FAQ, located elsewhere on this website.
--DD
Old 03-13-2001, 12:44 PM
Post
Correct me if I'm wrong. But, I believe the 2.0L started in 70 and ran through 72 as a six cylinder. I believe these are marked with 901xxx.
Then, 73-76 were 4 cylinders as mentioned above. I think you're only interesed in the 4's.
Old 03-13-2001, 01:53 PM
914 Geek
Porsche Crest
The 70-72 2.0 one is usually just called the Six... Usually when we just state "2.0", we mean the 2.0 four-cylinder engine.
--DD
Old 03-13-2001, 03:36 PM
Send a message via AIM to JP Noonan
Post
... not to be confused with the "GD" through "GE" (and beyond) which are bus motors and IMHO, nothing more than a PITA...
BTW if you can't tell the difference between a 2.0L Type-IV four cylinder and a 2.0L six cylinder... you should not be allowed to put gas in your own car.
Old 03-13-2001, 10:36 PM
