Want to be's Avatar
Porsche Crest Rivieras vs. 2.0 wheels
Which wheel is considered the best? I am purchasing a car with Rivieras and would rather have 2.o wheel.. Are they worth the same or less?
Thanks for any help.. Trades if possible...
Fakes OK with me...2.0....
jpc
Farmers Automotive 1-800-213-6373
http://www.farmersautomotive.com
1987 928S4,1989 911 25th, 1993 RSA, 1989 944,1988 911 1968 912, 1976 911 S, 1975 914
Engine dyno
http://www.youtube.com/watch?v=tJKdvrX_mTI&feature=youtube_gdata_player
Old 04-09-2006, 04:35 PM
914 Geek
Fuchs are forged, Rivs are cast. Fuchs are factory equipment, rivs are aftermarket. Fuchs are lighter. Fuchs often let you fit slightly wider tires in the rear.
Fuchs seem to be worth "about" $100/wheel. Rivs can be had for half that or less.
Fake Fuchs are cast, and heavier than the real thing. They seem to be worth somewhat less than the real thing when they are used--but I believe they can still be bought new. I personally don't like the idea, because I'm not sure how strong they are. The wheel was designed to be a forged piece, after all, and forged aluminum is stronger than cast.
--DD
Old 04-09-2006, 06:27 PM
Want to be's Avatar
Good point....but my914 will be more of a cruiser than a racer...
Fake or real... no big deal to me... thanks jpc
Engine dyno
Old 04-09-2006, 07:45 PM
mike mueller's Avatar
riv's are usually worth more for scrap aluminum than for the ability to mount a tire on it
there is a reason you see so many of them, they are dirt cheap (I think you can still find them brand new for about $60 a pop in the VW Bug mags.)
'73 914, 1.7, with Boxster transmission in the future?
Old 04-10-2006, 11:50 AM
Control Group
Tobra's Avatar
Offset on Rivieras is different from Fuchs also, which DD alluded to with tire fitment
Old 04-10-2006, 01:15 PM
Lots of Fuchs available in California for good prices. Seems they are not cool there anymore 'cuz everybody's got 'em.
I have a set of repros on their way to me. Very good price, of course now DD has me worried about them......
1971 914 1.7 parts car
1974 914 1.8 driver
Old 04-10-2006, 04:45 PM
I have never heard of a reproduction Fuchs failing (I have a cracked real 2.0 Fuchs at home with NO signs of impact)
Daves assumption ( ) is that the fake part is copied 100% off of an original one and not made thicker in the areas needed to have the same or near same strength as the forged part.
Old 04-10-2006, 04:52 PM
914 Geek
Very true, that is my assumption. I did not measure the fakes I had a number of years ago, which was a mistake in retrospect.
The wheels would not be DOT-certified if they were blatantly unsafe, and I'm pretty sure they are. But I do like the forged wheels better. If the fakes are thicker, then they are even heavier yet than the real forged ones.
--DD
Old 04-10-2006, 05:14 PM
Unless the porous nature of the wheel resulted in less material overall and hence reduced weight?
Okay, so I'm not worried anymore. And the wheels do look cool and we have all learned a valuable lesson.
When you make an ASSumption, you make an ASS out of U and Mption.....
1974 914 1.8 driver
Old 04-10-2006, 05:31 PM
Want to be's Avatar
I called Parts heaven to see the price differences. It appears the Fuchs are worth about $125 each and the other after market wheel $50 bucks.
What is the widest wheel width you can put on a 914? 5.5 inch?
standard 914....
thanks
jpc
Engine dyno
Old 04-10-2006, 06:29 PM
Acox914's Avatar
Send a message via AIM to Acox914
6" fuch or cookie cutter or some 7" wheels fit with the right offset....
7's fit fine up front, as the front track is an inch less per side.... compared to rear
-Aaron
"60% of the time, it works every time"
Old 04-10-2006, 07:27 PM
914 Geek
But you still can't fit anything wider than 205s, unless you are very lucky. And often enough, you can't fit 205s on 7" rims under the stock rear fenders--not without pulling them out a little way, at least on one side!
--DD
Old 04-11-2006, 01:09 AM
Control Group
Tobra's Avatar
My 195-60-15 on the fuchs rubs a bit on the L front wheel well, aft of the tire and only on extreme L turns. Spotted a few old rubs, and a nice new black one when I was putting on the second horn, and scoping out the fuel pump. Clears easily in the back. Maybe that L front fender got put on first thing on a Monday morning, or is cockeyed from some minor bump.
Old 04-11-2006, 07:46 AM
norustscott's Avatar
have you seen the 4 lug gas bunner reproductions???? hmmmmm.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C32%2DGBB
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 04-11-2006, 10:55 AM
nice...too bad the offset is still "buggy"
Old 04-11-2006, 11:03 AM
