-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Performance Questions... (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/273161-performance-questions.html)
timmcgraw67 03-23-2006 11:46 AM
I have a 1.8 914 and I bought 96mm flat top jugs and pistons and a Web Cam 426 lift 262 duration. I am hoping for 100HP, could someone help in advice... I talked to a local shop in tujunga but to check and build my motor they want $800. Anyone know any good builders but reasonably priced? Also is the Bosch 050 Distributor better than stock?
I live in the Glendale, CA area but work in Orange so anything along the way is fine. Drop me a line (818)551-1735.
nine_one_4 03-23-2006 11:52 AM
You'll get more responses to your question here but I can tell you that paying someone to work on your 914 is not cheap.
Dave at Pelican Parts 03-23-2006 06:00 PM
$800 is cheap for a rebuild on a 914 engine. I'd worry that the builders would cut lots of corners for that kind of money. :(
DIY, or pay someone big bucks. You can talk to the guys at FAT Performance in Orange, they've been pretty good in the past. But don't be surprised if the $$ is a lot more.
--DD
