Send a message via AIM to 0to60n10minutes
914 stance
ive noticed lately that my car loves to point its nose into the air, maybe its trying to show some pride, but im really not sure....?!?!?....haha but really, i have a friend down the street who owns an all original 73 914. i currently own a 72 914. what i want to know is, why does the front of his car sit SO low to the ground, where as my cars front end sticks up. is this simply in the struts? if so what kind of struts do you guys use to get the car lower. anywayz thanks for any replys
~alex~
Old 06-14-2006, 12:08 AM
Control Group
Tobra's Avatar
ride height is adjustable in the front I believe. I have not looked into it, but a torsion bar is a torsion bar, and the read of a IRS bug has torsion bars that set the height in back, try searching the club
Old 06-14-2006, 07:29 AM
914 Geek
You don't have to "search the club".
The front of the car has torsion bars, so adjustment is fairly easy. If you'll look in your Haynes manual, you'll find pics of the bolt you need to turn to raise or lower the car. Make sure to bounce the car and roll it around a bit in between adjustments, though!
The rear of the car uses coil springs. You cannot change the ride height unless you have some non-stock parts on there. Some Bilstein and Koni shocks have a lower spring perch that rests on a C-clip, which you can move to several different grooves. This will change the rear ride height. And there are "threaded collar" type kits that give you more "analog" adjustments of the lower spring perch as well. But those are all non-stock parts.
The rear springs do, after 3-4 decades, tend to sag somewhat. If your car is now more nose-high than it used to be, that is one possible cause. This usually only happens over the very long term, though.
--DD
Old 06-14-2006, 08:48 AM
does adjusting the torsion bars effect the alignment? i'm always afraid to mess with front end stuff for that reason...
Racer Girl
73 914 2.0
57 Vette (ok, actually dad's, but i get to play with it)
Old 06-14-2006, 12:39 PM
Yes it will change Camber and thus will affect toe. infact in a very small way castor.
Old 06-14-2006, 01:31 PM
