Ray Mital's Avatar
CHT Installation
I received my cylinder head Temperature sensor from Pelican....I'd like to install it. It was suggested to notch a socket to allow room for the wire.
....I'm doin' and learning a lotta new stuff, but notching or modifing tools might hold me up on this one.
Have any of you 914clubers "notched" a socket for this task. If so, could you lend it to me. I'd get it right back to you and pay shipping.
Thanks,
Ray
'73 914 2.0L driver
'73 914 2.0L parts
'74 914 2.0L project
Old 04-12-2006, 10:00 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Grind off one corner of a 3/8th extension so the wire can come out the top of the socket. It stilll works fine for other stuff, it just becomes a conversion piece in your toolbox.
make sure not to lose the copper gasket!!! It works to use a dap of super glue or hot glue a corner of the gasket to the cht so it doesn't fall down into the engine.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 04-12-2006, 10:05 AM
Ray Mital's Avatar
...sounds easy enough....will do.
'73 914 2.0L driver
'73 914 2.0L parts
Old 04-12-2006, 10:11 AM
Maybe it depends on the size of the socket and wire, but...
See if you can coil the wire up and fit it inside a deep socket.
Old 04-12-2006, 10:21 AM
Bleyseng's Avatar
BTDT and you will need a really long socket to fit all that wire.
Geoff
www.914Club.com
My Gallery Page
Old 04-12-2006, 11:23 AM
On my car, I just use a deep socket and stuff all the wire into the end of the socket before installing, it works everytime.
Old 04-12-2006, 11:50 AM
bd1308's Avatar
Send a message via AIM to bd1308
I cut a box out int he MIDDLE of a long 13mm socket to fit the wire through.
Took about an hour and three fiber cutting wheels.
b
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 04-12-2006, 12:03 PM
Ray Mital's Avatar
That's kind of what I figured......grinding down a corner will hopefully be quicker.....
'73 914 2.0L driver
'73 914 2.0L parts
Old 04-12-2006, 12:10 PM
