turn signal fix?
Hi All!
Boy did I get a surprise when I removed the 1971 broken turn signal indicator thought I could replace it with a later one without any problem at all. The union of the wires is not a problem. They are labelled the same, however, there is a chassis height difference. Any advice on how to compensate for it? I flubbed up the image I tried to attach. Let me know if you know something about this. Last edited by jjemg; 04-12-2006 at 09:15 AM.. |
