BigDBass's Avatar
Send a message via ICQ to BigDBass Send a message via Yahoo to BigDBass
how many speed bleeders?
Gonna order speed bleeders for my brakes. Do I need a total of 4 or 8 bleeders for my stock calipers?
Dan
1974 914 2.0 in Ravenna Green/Poop Brown
Old 05-11-2006, 09:57 AM
norustscott's Avatar
bleeders
just four...replace the ones on the top...
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 05-11-2006, 10:10 AM
JW Apostate
trekkor's Avatar
I have all 8. Why would you skip the lowers?
( they are not for decoration )
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 05-11-2006, 10:23 AM
iamchappy's Avatar
Dan's running with the stock brakes I bled them when he was up here picking up the car. But I would also like to know why only 4.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 05-11-2006, 10:44 AM
"Speed Bleeder Nipples (optional. If you get them, get 4. One for each caliper)"
My final recommendation is to replace the bleeder nipples with speed bleeders. These things are worth their weight in gold. If your calipers have both an upper and lower set, you need replace only the upper ones."
From the the rear brake rebuild article on Pelican. My own thought is that air will seek higher ground...lol...
Scott
1982 911 SC
1962 sunroof bug
Old 05-11-2006, 10:53 AM
914 Geek
Air bubbles rise. If you are bleeding to get the air out, you only need to use the top bleeders. The lower ones seem to be to help get all the old fluid out faster when you flush (change) the brake fluid. This is done much less frequently than bleeding (theoretically), so using the more-$$ speed bleeders on the bottom fittings seems to be a waste of money.
Unless you want to use 'em--they won't hurt anything! And they could make your bi-annual brake flush take less time...
--DD
Old 05-11-2006, 12:25 PM
BigDBass's Avatar
Thanks guys. I'll probably go for all 8 just for the sake of thoroughness. So when it comes time to install these, is brake fluid gonna squirt all over the place or will it just be a little leakage as long as the brake pedal isn't being pumped or pimped?
Dan
Old 05-11-2006, 01:01 PM
no.. you need to put a hose on the bleeder and a catch can....i had to run a whole can of ATE blue before getting all of the air out...and one at a time....and go slow with the pedal...
Scott
1982 911 SC
1962 sunroof bug
Old 05-11-2006, 01:05 PM
BigDBass's Avatar
I mean just the installation of the speedbleeders, not the bleeding process itself.
Dan
Old 05-11-2006, 01:10 PM
ah...then it will just weep a little....gravity will cause it to drain. put something down and work fast...lol
Scott
1982 911 SC
1962 sunroof bug
Old 05-11-2006, 01:12 PM
iamchappy's Avatar
I LOVE the Speed Bleeders. Best bang for the buck.
87 924S
Lexus SC400
Lexus LS400
Old 05-11-2006, 01:21 PM
This may seem obvious but .... When fluid is leaking out keep the reservoir full. Once air gets into the master cylinder or proportioning valve bleeding becomes much more difficult.
I don’t know if this will work to minimize brake fluid leakage but I’d try it. Hook up your bleeding kit to one of the bleeders and bleed fluid out until the brake pedal is fully depressed. Then hold the pedal fully down with a 2x4 or a rod, be creative.
With the pedal fully depressed and the reservoir cap on replace the bleeders one at a time. Check the reservoir with all bleeders closed often.
After you are done be sure to bleed the brakes.
IIRC the Haynes manual says something about keeping the brake pedal depressed and a special Porsche tool to do it.
Old 05-11-2006, 01:37 PM
jsteele22's Avatar
From someone who [I]HATES[/I} brake fluid :
Have you thought about getting a pressure bleeder (from our generous hosts at PP) ? I got one and it is indescribably better than anything else I've ever used on brakes. You dump a quart of fluid in the reservoir, pump it up to the desired pressure, and then one by one you can open the bleed niupples and a whooshing stream of fluid comes out (use a short hose to catch it.) Sludge, bubbles, grit, whatever don't stand a chance. And you can do it by yourself, no brake pumping involved.
Old 05-11-2006, 01:59 PM
smontanaro's Avatar
Silly question perhaps, but where do you get speed bleeders? The PP
catalog doesn't list any for 914s or 914/6s. They list several for various
911s. You'd think if they worked on 914s they'd show up there as well.
Thx,
Skip
Old 05-11-2006, 03:04 PM
BigDBass's Avatar
Hi Skip,
PP has them with part number PEL-SB7100.
You can also get them directly from speedbleeder.com, I believe, but I want to support the this site for giving us a place to "hide"
Dan
Old 05-11-2006, 03:07 PM
