Send a message via AIM to addwestern
Time Sert for stripped plug
Anyone know what size is the best for doing this job? Came across a great running 1.8 liter engine yesterday that had the #1 hole stripped.
It was out of the car, had contemplated dropping a replacement head on it, but in reading past posts, I've heard favorable things about the Time Serts.
I doubt I'll keep the engine, but want to give a good complete runner to the next owner.
Current project: 73 914 2.0
"PT 914"
www.914-parts.com/73.jpg
Last car 73 914 1.7(I was stupid to sell it)
http://www.ecklerfamily.com/galleri...sche/index.html
Old 06-01-2006, 08:08 AM
Banned
I think you'll get more responses on the Type 4rum or Raby's forum .
Old 06-01-2006, 11:07 AM
914 Geek
At least one of my spark plug holes has been TimeSert'ed. It was done when the heads were off at the machine shop, though. I think it might be quite a challenge to install one (cleanly, with no chips or shavings going into the cylinder!) without pulling the head.
But I didn't do the work myself, so it might be more straightforward than I think it is.
The TimeSert works fine. It feels a little weird when installing the plug (it gets tighter and losoer as you turn) but that's really the only difference.
--DD
Old 06-01-2006, 02:45 PM
John Rogers's Avatar
My racing buddy Ted with his 356 last year ended up installing time serts on all 4 spark plugs at a vintage race one weekend. He blew a plug each session until the last and they all stayed in finally. It can be done with the engine in the car, just take your time, use some thick grease to hold any chips and maybe pray a little.
Old 06-02-2006, 08:37 AM
Thanks alot
Thanks for all of your help- the engine is not in the car- it's an extra. Got it posted in the For Sale area- figured I'd try just selling it cheaper first- more time and money to be put in my own car...
If not, guess I'll have to break down and fix it...
"PT 914"
Old 06-02-2006, 08:55 AM
Member w/ Title Problems
Jason Porter's Avatar
I'm really a fan of having the machine shop weld it up and re-tap it to stock when the heads are already off, and yes, you can easily install the timeserts with the engine in the car. However, that being said, it's also much easier to go in crooked with the engine in the car, as your laying on the rear trunk lid wishing you had better access. Just watch what you're doing, and use thick grease as mentioned earlier. Go a half turn or a turn, back out, clean, regrease, and repeat...
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 06-04-2006, 08:53 PM
norustscott's Avatar
go slow....
i did it...grease, go slow. if you do it right it should take you almost an hour or more . I say an hour because you should remove the reamer/tap tool about every turn to clean and re grease. Then you will check, double check and still worry about lining the reamer/tap up correctly each time. you will also get tired...weird angle and you must keep pressure on the tool the entire time....push, 1/4-1/2 turn, reverse 1/4 and repeat...always keep pushing it you are turning to cut new threads.
Don't hurry, it is actually a great solution. I think 911 actually have inserts stock...?
scott
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 06-05-2006, 11:59 AM
