HELP! engine stalls
Hi, guys. I need your help.
I was adjusting timing by turning the dizzy and, when I was tightening the bolt that holds dizzy in place, I saw a spark and then my engine started to die and stopped. I tried to start it again, it fires a couple of times and stops. I probably touched a wire (+) connector (partly exposed) and a distributor with a wrench. so, I think I burned something....
condencer? computer? Fuses?
Thanks....
Old 09-01-2006, 04:19 PM
914 Geek
Open up the distributor and look at the points and the wires to and from them. Unplug the green condensor wire from the points (at the distributor), and make sure the points give you a good ground when they're closed.
Also make sure you've got +12V at the black (or black/red) wire going to the (+) terminal on the coil when the key is in the "on" position.
--DD
Old 09-01-2006, 05:12 PM
Dave, somehow I knew that you will answer today. Thank you. I will come back and check my car tomorrow.. hopefully it won't rain a lot ))
1973 914 yellow (retired)
1987 924S white no sunroof
Old 09-01-2006, 05:50 PM
CHECKED:
1 - the points have a good ground (closed and disconnected from the condenser)
2 - in this condition I checked the voltage on + coil terminal - it's 11.61
I didn't do anything else - no engine cranking, no other tests.
What else should I do?
BTW, prior to this fiasco, the engine's idle was not steady - between 800 and 1000 rpms.
Old 09-02-2006, 06:24 AM
Control Group
Tobra's Avatar
It is possible you grounded and cooked the condensor. Check for spark however you prefer, I like to pull a plug wire and stick a spare spark plug on it, crank and watch for spark for God's sake don't touch it.
Old 09-02-2006, 06:39 AM
Thank you, guys.
Here's an update:
I did as you, Tobra, told, cranked the engine (it was turning with a struggle) one time, second and it started on third. turned it off. reinstalled the spark plug wire and crank the eng. egain. Again, first try - the starter was hardly turning the engine, on the second try - the eng. started.
As the engine was idling at 2500, I head some detonation.
Uneven idle (when warm).. could it be caused by a different compression in the cylinders?
Old 09-02-2006, 10:27 AM
bd1308's Avatar
Send a message via AIM to bd1308
I bet your timing is all messed up.
Too advanced timing = hard to start
b
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 09-03-2006, 06:18 AM
