-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Turn Signal Switch Doesn't Return to Neutral (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/293631-turn-signal-switch-doesnt-return-neutral.html)
73ess 07-15-2006 08:50 PM
After I complete a turn, my turn signal switch doesn't return to the neutral/off position. Happens for both left and right turns. What could be the problem?
Thanks,
John Rogers 07-16-2006 12:48 PM
Inside the steering column is a disk shaped piece that has a tab on it so that when the wheel is turned back after a turn it touches the inside of the signal switch. They tend to break off after 30 years or so of use and I don't think they can be bought any longer so manual canceling will be required. If you decide to replace the turn signal stalk you'll see it when you open things up.
