-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   limited slip additive help syncros? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/297822-limited-slip-additive-help-syncros.html)
Will98D 08-09-2006 06:57 AM
My trans shifts OK sometimes, finicky others. Changed all the bushings; aligned shifter best as I can (sometimes nicks reverse on a 4-2 downshift into 2nd, never upshifting; strange, but if I adjust anymore to get the 2-3 gate away from 1-2 then it won't go into 4-5); changed gear oil when I got it, then again recently after 3,000 miles. Used regular 80W-90 oil, not synthetic. Most irritating is that when I shift into 1st it is sometimes hard to get it to go in. I almost always try to engage it as I roll to a stop, but even then it will occasionally feel like the teeth are not lined up and need to try again once or twice before it will drop in.
So far it does not pop out of any gears, and doesn't seem noisy.
After all that, has anyone ever added limited slip additive to their transaxle? Do the cars with a LS diff use the additive, and did any of you notice a change in the way the car shifts. I was thinking maybe it would help the syncros a bit. TIA.
Tobra 08-09-2006 12:47 PM
I get into 1st easier if I put it in 3rd first, 2nd before I try reverse and it goes in well. How are the springs that keep you from going into reverse? I am guessing worn.
More likely you have worn synchros. WHen I adjusted my shifter, I ended up having to support the shift rod underneath or it would rotate counter-clockwise. After doing this, it shifted much better.
Don't think additives will help, but who knows(Dr Evil would be my guess)
djpateman 08-18-2006 01:11 PM
I used to use Molyslip G in my trannies, without problems that I recall, but it has be at least 20 years. The synchros in the 914 tranny are not designed for that however. They require a certain amount of friction to work properly.
