limited slip additive help syncros?
My trans shifts OK sometimes, finicky others. Changed all the bushings; aligned shifter best as I can (sometimes nicks reverse on a 4-2 downshift into 2nd, never upshifting; strange, but if I adjust anymore to get the 2-3 gate away from 1-2 then it won't go into 4-5); changed gear oil when I got it, then again recently after 3,000 miles. Used regular 80W-90 oil, not synthetic. Most irritating is that when I shift into 1st it is sometimes hard to get it to go in. I almost always try to engage it as I roll to a stop, but even then it will occasionally feel like the teeth are not lined up and need to try again once or twice before it will drop in.
So far it does not pop out of any gears, and doesn't seem noisy.
After all that, has anyone ever added limited slip additive to their transaxle? Do the cars with a LS diff use the additive, and did any of you notice a change in the way the car shifts. I was thinking maybe it would help the syncros a bit. TIA.
2005 BMW 530i
2008 GMC Acadia
Old 08-09-2006, 06:57 AM
Control Group
Tobra's Avatar
I get into 1st easier if I put it in 3rd first, 2nd before I try reverse and it goes in well. How are the springs that keep you from going into reverse? I am guessing worn.
More likely you have worn synchros. WHen I adjusted my shifter, I ended up having to support the shift rod underneath or it would rotate counter-clockwise. After doing this, it shifted much better.
Don't think additives will help, but who knows(Dr Evil would be my guess)
Old 08-09-2006, 12:47 PM
djpateman's Avatar
I used to use Molyslip G in my trannies, without problems that I recall, but it has be at least 20 years. The synchros in the 914 tranny are not designed for that however. They require a certain amount of friction to work properly.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 08-18-2006, 01:11 PM
