Replacing front rotrs this weeked???
Doing that hopefully this weekend.
Was looking in my hanes manual for the torque specs on the nut for the end of the shaft after i put the new wheel bearings and the rotor on. I think it said 11lb/ft. i thought that might be a lil on the low side. Any input is greatly appreciated. THanks, Billy |
Sounds about right. You can check the adjustment by moving the washer with the tip of a screwdriver. If you can move it sideways WITHOUT prying, then it's OK. BE SURE you have the SAME rotor as you're removing. There are 3 different rotors. The Cap'n
Ah cool. Thanks for the tips. I read about the 3 different rotors in the Tech Tips 700. I will make sure that i have the right ones before i go working on it.
thanks, Billy |
There is no torque spec for the thrust hex nut. There is a spec for bearing adjustment, however. You should be able to slide the thrust washer around with the tip of a screw driver ( as stated above).
The 11 ft-lb torque spec is for the clamping screw on the thrust nut. |
What they said. 11ftlbs. on the allen head once the nut is in he proper position (which is the washer and screwdriver trick).
here are the pics of the front and rear rotors that i got.
Im pretty sure the fronts are the correct ones, not sure about the rears. Let me know what you thinkhttp://forums.pelicanparts.com/uploa...1156969987.jpg |
What year is your car? The Cap'n
74'
Those appear to be correct. You have new front wheel bearings and seals? The Cap'n
Hey wheres the studs?
Changing tires at te track is much more enjoyable with studs. What?????????? Doesn't everybody race thier Teener?????????? |
Some of us aren't as thrilled as you are about hanging out with studs at the track ....................... LOL, The Cap'n
cool thanks for the confrimation on that.
As far as studs go. It would be nice wouldnt it? I do intend to eventually track this thing esp since i just had a motor built for it. Just not yet though. _billy |
That's freaking funny. specially from you..........:rolleyes: Chicks dig a guy that carries big nuts and knows how to torque them. |
Oh please...
Billy, the rears are all the same. |
| All times are GMT -8. The time now is 10:27 AM. |
