Going rate for wheel bearing replacement?
I have a 70 914-6 that sounds like it needs a wheel bearing. What should I expect to pay to get this fixed?
Front or rear?
rear
If the mechanic knows what he is doing it should take less than an hour.
I would figure under $100.00 plus the parts. |
not bad
A lot mor than $100
Don't know if there is much of a difference between the 6's and 4's but I wast quoted $700+ by two different shops last month. Parts and labor.
Ken
Ken Schipper kenschipper@hotmail.com '74 - 914 Pheonix Red 1.8 soon to be 2.0 |
rear wheel bearings can be a pain. The nuts are torques to 300 lb-ft or some ungodly number. I think when I had one done a few years ago it was $150 or $160.
Re: A lot mor than $100
The Cap'n |
Most shops around here will be $250 a side for rears.
If you get charged full retail, that bearing is $100 all by itself. To that, add the labor. The $250 per side isn't far off.
DYI; $50 bearing from parts house and some elbow grease, etc. AJS |
grind weld build
shop rates average 60-80 per hour
2 hours 140 bearing 100 total 240 sounds reasonable a pro shop will have teh tools and know-how to do it faster but you still pay for that knowledge.
flesh heals, memories last forever! 73 Orange, CS #601 73 Rayco V8 glug, glug 69 911 w/82 turbo look on 275 35 18s (for sale) Trek 6500+ Sean M! |
local shops are 90/hr
-Aaron "60% of the time, it works every time" |
I removed the trailing arm and had a shop push the old one out and press the new one in for $40. Dropped it off on the way to work and picked it up on the way home. Had to re-align the toe and I painted the trailing arm while out of the car.
Spoke |
$90/hour? Damn I gotta raise my rates.
for reference, the "best" porsche shop around boston (autosport engineering) charges 100/hr. And they are in the sticks...
the best vw place that works on air cooled porsches and is in the city...70. ![]() |
PMB Performance
We recondition the whole arm(s) for $295.00
You gotta get them to me though ![]()
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
