Send a message via AIM to Jake Seidel Send a message via Yahoo to Jake Seidel
Need response quick !!!
I just drove to school with all my stuff in my front trunk and now I pull the hood realease and nothing happens. What do I do to open the trunk? I need to get it open to get my books and stuff out
thanks
jake
Jake seidel
72 1.7 914
90 Honda Accord
91 Honda Accord
95 BMW 540i FS
Old 08-31-2006, 05:17 AM
bd1308's Avatar
Send a message via AIM to bd1308
You need a 13mm wrench and a doctors note, bc you did what I did a while back, and you'll need to get the bumper off.
b
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 08-31-2006, 05:20 AM
bd1308's Avatar
Your trunk release sheath on the cable broke, nort surprising because most are 30+ yrs old.
Anywho, take bumper off and you'll see a hole in the middle of the actual front trunk pan. Take screwdriver and slide little nub and trunk will pop open.
Happened to me in the middle of nowhere in OHio at around 2:30am at a gas station.
That was a LONG night, but the trunk procedure takes ~15mm'
b
Old 08-31-2006, 05:22 AM
In the Haynes manuel page 197 sec 14.
1. Remove front bumper
2. Remove the rubber plug form the cross panel, just above the lower part of the lock.
3. Actuate the lock bolt to disengage the lock using a screwdriver.
Hope this helps good luck.
Old 08-31-2006, 05:30 AM
SGB SGB is offline
SGB's Avatar
BTW, the bolts that hold the bumper are accessable from the wheelwell.
-Scott
My gallery page
Old 08-31-2006, 05:36 AM
bd1308's Avatar
Indeed, turn car one way to access bolts from side A and vice versa for side B.
4 bolts, no biggie.
Old 08-31-2006, 05:38 AM
RETIRED
Joe Bob's Avatar
Unless they are rusted....then it's a biggie.
2012 ML350 3.0 Turbo Diesel
Old 08-31-2006, 06:33 AM
sww914's Avatar
Will the bumper fit in the car if the bolts break off?
Old 08-31-2006, 07:57 AM
Thanks I found it in my haynes
Jake seidel
72 1.7 914
90 Honda Accord
91 Honda Accord
95 BMW 540i FS
Old 08-31-2006, 05:37 PM
