Electrical Wiring Diagrams
I am in the process of re-wiring (because I can). Am going to install the fuse conversion kit (see previous thread). Oh, by the way I have a 1974 914 1.8 converted to dual Weber 40'S.
My problem is reading the iffy electrical diagrams. Take for example current tracks 29 through 39. Have no problem with the fuse designations but have problems with the numbers in small squares such as: 59, 4, 23, 16. Also current track 30--Gray wire from K on Ignition to fuse 7; after the fuse the splits gray to #59, black/blue wire to "E20 Instrument panel illumination potentiometer". is there such a thing? Where does the Black/Blue connect, it says 58a but where does it go after that? Is there a BETTER set of wiring diagrams available? |
914 Geek
Re: Electrical Wiring Diagrams
One wire goes to pin 58 on component E3, which is the emergency flasher switch. One wire goes to component L21, which is the light inside the "DEFROST" gizmo next to the heater control lever on the center tunnel. A third wire goes to two L6es, one L7, and two L26es--two speedo illumination lights, one combo gauge illumination light, and two tach illumination lights. The final wire is continued on track #4, where it connects to three L16s, which are the lights in the heater/fresh air control assembly. Quote:
You can make your own diagrams, too, of course! If you're up to rewiring the car completely, you should be able to make a diagram that works better for you. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
