-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Broken Right Side Trunk Bracket Hinge (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3148-broken-right-side-trunk-bracket-hinge.html)
Kevin@ojai.net 06-03-2001 08:35 PM
Any help would be appreciated -- Today when putting some groceries in my rear trunk the right bracket mount broke. I am talking about the area in the engine compartment that the upper bolt on the hinge bolts into. My only thought would be to replace the bracket with a new one, but cant find any where that has them. Any ideas?
Thanks,
Kevin
'72 914
Dave at Pelican Parts 06-03-2001 09:33 PM
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_chasis_pg1.htm#item1
Look for "914 Trunk Hinge Plate". Basically, cut off the old one and weld in the new one in the same place.
--DD
Kevin@ojai.net 06-03-2001 10:09 PM
Thanks -- I couldn't find that earlier.
-Kevin
TimW 06-04-2001 06:58 AM
If your in the Milwaukee area and need help with the job let me know. I’ve done it before with the PP part. Not a huge deal – except for that blasted torsion spring...
Tim
