-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   console clock adjustment (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3204-console-clock-adjustment.html)
prattrc 06-09-2001 07:51 AM
In the tech article on clock rebuilding, the author mentions the ease of adjusting the speed on the old style clocks (externally) but doesn't say how. How do you adjust the speed? My clock drops 5-7 minutes a day. Can this be adjusted or do I need to rebuild or buy a new one altogether?
Ray
73 914 2.0L
campbellcj 06-09-2001 09:53 PM
There is a little adjuster screw -- but only if you have the early Type I clock, not the Type II or even later VDO Quartz clock! I think you missed this at the end of the tech article:
<font face="Verdana, Arial" size="2">
Adjustment of the clock speed is made by the small slotted screw which protrudes through the rear cover. Counter-clockwise goes faster. Best that I can tell, each 1/8 of a turn affects the clock by about 5 minutes per day.
</font>
Good luck,
Chris C.
Chris C.
73 914 2.0
70 911E Targa
campbell.chris@gte.net
[This message has been edited by campbellcj (edited 06-09-2001).]
prattrc 06-10-2001 01:32 PM
I did miss the end, thanks for your help!
Ray
73 914 2.0L
Wayne 962 06-10-2001 02:04 PM
They still don't keep good time...
http://www.pelicanparts.com/ultimate/frown.gif
-Wayne
mejulihn 06-10-2001 04:25 PM
The newer one from the VDO "Cockpit" series that I installed in my car keeps very good time. If this feature is important to you, you may want to consider upgrading.
