Question console clock adjustment
In the tech article on clock rebuilding, the author mentions the ease of adjusting the speed on the old style clocks (externally) but doesn't say how. How do you adjust the speed? My clock drops 5-7 minutes a day. Can this be adjusted or do I need to rebuild or buy a new one altogether?
Ray
73 914 2.0L
Old 06-09-2001, 07:51 AM
Stay away from my Member
campbellcj's Avatar
Post
There is a little adjuster screw -- but only if you have the early Type I clock, not the Type II or even later VDO Quartz clock! I think you missed this at the end of the tech article:
Adjustment of the clock speed is made by the small slotted screw which protrudes through the rear cover. Counter-clockwise goes faster. Best that I can tell, each 1/8 of a turn affects the clock by about 5 minutes per day.
Good luck,
Chris C.
Chris C.
73 914 2.0
70 911E Targa
campbell.chris@gte.net
[This message has been edited by campbellcj (edited 06-09-2001).]
Old 06-09-2001, 09:53 PM
Post
I did miss the end, thanks for your help!
Ray
73 914 2.0L
Old 06-10-2001, 01:32 PM
mejulihn's Avatar
Post
The newer one from the VDO "Cockpit" series that I installed in my car keeps very good time. If this feature is important to you, you may want to consider upgrading.
Old 06-10-2001, 04:25 PM
