Wiring Hazard Switch Part 2
The terminals on the Hazard Switch are:
Wire Red w/white stripe to terminal 15 Wire Black w/Red to terminal 30 Wire Black w/Blue to terminal 58b Terminal 31 to Ground Terminal 49a to Hazard/Turn Signal Flasher Terminals R and L are for front and rear turn signal lights My question is WHERE DOES TERMINAL PLUS(+) GO?? http://forums.pelicanparts.com/uploa...1166658162.jpg http://forums.pelicanparts.com/uploa...1166658188.jpg Haynes doesn't show this connection. The second question is: http://forums.pelicanparts.com/uploa...1166658318.jpg The wire diagram says that this is a "CABLE CONNECTOR, SINGLE" and goes to "CABLE CONNECTOR BELOW CONSOLE" Someone please solve my dilemma |
OK, leave it to eBay to provide the pics.
Ebay ad 250055828940 is for the "late" switch. Here's the picture of the terminal arrangement : http://www.a2eurotec.com/i/ebay/f/1150593516.jpg Looks just like your switch. They're also selling a "early" switch with no resistor and a missing terminal 54, where your 58b is located, ad number is 260003899475. |
OK, so I'm looking at the 1973 wiring diagram on Pelican:
http://www.pelicanparts.com/914/parts/Electrical/914_electric_73A.jpg I'm assuming this is the right one since you seem to have a "late" switch. I see the following terminals: L R 15 30 31 49 49a 58b The switch has: L R 15 30 31 "+" 49a 58b If you map 49 on the wiring chart to "+", looks like it makes sense. From what I can see, 49 is a single red wire that comes from component 47 (terminal 49), which is identified as the "turn signal/emergency flasher unit". |
I just noticed that component 47 is called a "direction warning blinking indicator" in the early wiring diagrams - I assume this is blinker relay?
Weird. Now that I look at your switch some more, the 58b connection is odd. Look at the wiring diagram, 58b is connected to a blue/black wire that goes to a junction that current to all of the instrument backlights. 58b is then connected to a 300 ohm resistor, and on the other side, is connected to ground (via terminal 31 in the wiring digram, looks like a direct connection to the case rivet in the photos above).
What the heck is the purpose of this? Looks like it's just a 300 ohm load on the instruments lights circuit. I don't see it has any functional purpose with the hazard switch at all. |
When you pull on the hazard light, you get a full 12V supplied to the light for a brighter light, flashing in sync with the hazard lights. |
BTW, you can verify that the "+" terminal is really terminal 49 in the diagrams by testing the switch with your DMM. Put it in to continuity mode, push the switch in, and touch the "+" terminal and terminal 15. Does it beep? If so, switch from terminal 15 to terminal 30, then pull the switch out. Does it beep? OK, it must be terminal 49.
| All times are GMT -8. The time now is 02:25 PM. |
