canna change law physics
red-beard's Avatar
Question Hand Brake Cable Adjustment
I just finished changing the pads on the read (what a pain!). I thought the problem with the hand brake stemmed from not enough pad. It looks like I just have too much slack in the cable. I couldn't find any adjustments on the cable.
Old 06-12-2001, 09:40 AM
Post
If you look at the firewall where the cables enter into it, you will see some rubber boots. Under those boots there are adjusters to take the slack out of the cables.
Clay Perrine
74 1.8L Signal Orange "Frody" (My Wife's Daily Driver)
73 2.4L MFI Six "Igor" (Under Construction)
"Friends help you move. Real friends help you move all your 914 parts"
Old 06-12-2001, 09:54 AM
paulhagedorn's Avatar
Send a message via ICQ to paulhagedorn
Post
Also remember there is an adjustment on the rear calipers for the parking brake. I am not quite sure what is necessary to adjust this seeing as to how my car has no parking brake whatsoever. I have been too busy(or lazy) to go out and fix it.
Paul
Old 06-12-2001, 09:59 AM
red-beard's Avatar
Thumbs up
Thanks, I'll look at the firewall tonight. I need this to pass inspection!
Old 06-12-2001, 10:10 AM
Post
I believe the "venting clearance" for the rear calipers (measured between the brake pad and the rotor) is .008" and is adjusted by the allen adjuster screw on each side of the caliper (usually under a plastic cover). The outside one is obvious, but to reach the inside one, you have to go through a the hole in the trailing arm with a LOOOOOOONG allen.
Eric
Old 06-12-2001, 01:09 PM
red-beard's Avatar
Talking
I know about the inner allen. I ended up having to remove/replace a caliper because of the inside one being mucked up.
And hey, I'll working on putting your weber's on the '73 this weekend! Along with the heater flapper valves.
If I can get _one_ of them inspected and offcially on the road, I'll be happy!
Then I paint them!
Old 06-12-2001, 01:17 PM
