I am in the process of purchasing 1972 911T front Boge strut housings with new inserts,hubs,brake calipers and all caps,bolts etc. that I will be installing in my 75 914 chassis. I will be installing new tie rod ends and ball joints is there anything else "while I'm in there"? I will be retaining the 914 A arms and will replace the bushings on those in the future. Is there anything I have to do at the top of the shock tower? Anything I've missed? Thanks
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Nope those wont work on a, What year did you say yours was? No those wont work on a 75. Just ship it to me and we can call it even
It sounds like you have everything. Bushings, paint, check the arms for cracks, wear etc. What did it cost you, and what are you doing for the rear? Also check the pelican tech area, I believe there is a write up on this exact mod. I think there is a bearing upgrade for the top mount, also flush / bleed the brakes since you will open the system. Pads? Measure the rotors to check that they are good. Triple check EVERY bolt and torque EVERYTHING. Oh yeah use jackstands, just remember to get the car off of them eventually.
999999999 1 4444 Last edited by 914fan; 01-05-2007 at 12:49 PM.. |
914fan I think I payed fair market price for all that was included. For the rears the previous owner had them redrilled to the 911 5 lug pattern so I think for now I'll go with that. I haven't mic'd the rear rotors but I think they're O.K. This car will be on jack stands for probably the next 2 years + as I am going to do GT flares and a 6 cylinder conversion. Also will be doing chassis stiffening,some rust repair etc. etc. I am really concentrating on getting the chassis right before I start my search for an engine.
Just be sure you get the correct ball joints for the STRUT, and new fasteners for that as well.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Is there any differences when using the front suspension off of a longhood compared to an impact bumper 911?
Do you need the A arms off the 911 or just the struts?
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
It's my understanding that you only NEED the strut housings and struts and they will work with the 914 A arms. You can however also install the 911 A arms if you want to, I believe you gain a larger torsion bar. My A arms look to be in very good shape so I will use them. The money saved by reuseing the A arms will help pay for new Elephant Racing polybronze bushings and larger torsion bars.
OCD project capitan
Guys, heres the skimmy...
The only determining factor with sturts is using the correct ball joint that fits in the strut. The bottom of the ball joint that fits in the A arms are all the same (911 '68-'89, 914 all). The 914 A arms and 911 A arms are different ONLY by the spline for the torsion bar. Same sizes should be available for both, but I would assume the 911 A arms would have more options with regards to performance parts like hollow bars. As for the sturts and strut housings, I don't have all the veriables list next to me, but give our host a call or GPR a call and they will get you squared away.
Don Welch '73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper. |
