-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Failed CD boxes on stock 914-6 ignition (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/327812-failed-cd-boxes-stock-914-6-ignition.html)
SanDiegoDon 01-30-2007 10:55 PM
Went out to start the 6 today. She's got a stock Bosch Ignition system, Bosch distributor and CDI box.
Anyway, she cranked but wouldn't start. So I hooked up a timing light to check for spark, no spark. Installed a spare Petronic's CD box to replace the original Bosch CD box. Started right up.
Let her run for about 10 minutes while checking some other things, lights, turn signals, etc. Reached in to goose the throttle, she died and wouldn't restart.
Hooked up the timing light again, no spark. Replaced the CD box with my last spare and she fired right up.
Now I'm wondering if this is just coincidence or is there something causing the CD boxes to fail.
It's got me baffled, I know that's easy to do.
Anyone got any ideas, I really hate to fry these things, they're not cheap.
Any help appreciated.
Thanks, Don
Nostril Cheese 01-31-2007 08:36 AM
MSD 6AL
I burned up three pertronix before switching to MSD and never had a problem again. The Pertronix are just garbage in my opinion
Rouser 01-31-2007 09:40 AM
Re: Failed CD boxes on stock 914-6 ignition
Thanks, Don
Exactly which Pertronix "CD" box are you talking about, and how did you wind up with so many "spares"?
There are many who have their own "personal" opinions about Pertronix products, since the items aren't necessarily "goof-proof". :rolleyes:
911quest 01-31-2007 11:44 AM
I think you have another problem, its just a coincidence i would check the points and also the coil you might try wiggling the wires also it might be when you unplug the CDI you are making a loose wire connect again dont forget the coil wire, also the cap could also cause the problem you didn't state which wire you are checking for spark at
SanDiegoDon 01-31-2007 01:30 PM
It's Perma-tune not Pertronix CD boxes, sorry about that. A friend sold his 914-6 and had 2 CD boxes that the buyer didn't want to buy, also had a bunch of spare parts, so I bought the 2 boxes for $100 and some of the other parts. I like spare parts. I was restoring mine at the time.
I checked the spark with a timing light
Anyway,
Ok, cleaned checked all connections, checked for shorted wires, worn/abraded wires. Found nothing wrong.
Replaced MSD coil with orginal Bosch Coil, installed my last Permatune Module.
Fired right up, nice steady low idle while cold, warned up, came up to normal idle, nice and steady. Pushed throttle linkage, rpms came up nice and smooth, ran perfectly.
All auxilary circuits working normally, charging, lights, instruments, etc.
In other words, except for the ignition modules dying, everything else checks out fine. I hate that, damn. Maybe it was just coincidence.
Anyone know where I can get the Bosch CD module checked/rebuilt, I know they can be rebuilt ? Left a message at Perma-tune to see if they rebuild them. It's going to be a while before I trust the thing and would like to carry a extra, just in case.
Just another day in paradise.
Don
911quest 01-31-2007 02:29 PM
I bet if you plugged one of the other three CDI boxes in it would still start
SanDiegoDon 01-31-2007 05:02 PM
Just found a test procedure on the Permatune site, the CD Box failed. Tried plugging in the Bosch, no start, no spark.
Just a bad day for CD boxes
Don
Joe Bob 02-02-2007 03:17 PM
If you have any Bosch boxes.....3 or 6 pin...send them to me.
ischmitz 02-05-2007 10:27 PM
Don, let me know if you need help. I can test/rebuid these boxes: 3.6@cox.net
Ingo
(if you already sent an email please resend since I had trouble with my inbox)
SanDiegoDon 02-06-2007 07:59 AM
Thanks, I replaced the CDI box yesterday with a Improved/rebuilt box from Capt Krusty and sent him the failed box. She's running sweet now.
Don
