Dang. I'd finally gotten myself geared up to buy a set of 195/60/15's or 195/65/15's to replace my ratty old 165's. Unfortunately,I may have done a bit too much research: I found a posting from two years ago where a member says he doubted that 8-spoke Empis could handle 195 tires because the offset isn't right. Can anyone confirm or refute that? Here's a pic of my wheel w/the 165's:
Somebody say it ain't so! In the event my wheels & 195's are compatible, any recommendations between the 60-series and 65-series? Thanks, Mark ------------------ 1971 1.7l 914 Willow Green |
RETIRED
There's a guy named Joe Schneider. Long time PCA member and shop owner. He runs those wheels on his 914. Call him 805-962-8015.
914 Geek
You could measure the actual clearance on your car. 195-width tires are about 30mm wider than 165-width tires. Half goes on each side, so you'll need ~15mm (0.6") of room on each side of your 165s. Figure out a "safety factor" for things to move around, and add that. See if you have that much clearance on each side of your 165s.
--DD |
Dave,
What's a reasonable "safety factor?" How much clearance between tire & fender lip is enough? Mark |
914 Geek
I don't really know. Part of it depends on how much you think things are flexing/shifting/moving, and how close to the "edge" you want to go. I've heard of people running around with less than 1/4", but that would make me a bit nervous. I'd think about 1/2" for a 914 in good shape would be more than adequate.
--DD ------------------ http://www.pelicanparts.com/gallery/Dave_Darling |
Stay away from my Member
I just put some kumho 205/50x15's on my fuchs (4lug), and there is enough space between the rear tire and the body to easily slide my hand in there. No rubbing. So I'd figure that 1/2-3/4" "wiggle room" is about right.
Let me help to confuse the tire/wheel issue a little more....We HAD some 195x50 Yoko A008s on a set of EMPIs (5 inch wide)and they fit fine, lots of clearance. We HAD some 195x60 Firehawks on the Fuchs (5.5 inch wide) and they fit fine. I bought some new 205x50 V700s and put them on the Fuchs and they still fit fine, BUT I moved the Firehawks to the EMPIs and they rubbed slightly in the rear! So I rolled the fender lip, etc and have about 0.5 inch clearance! Different backspacing it seems. Good luck.
OK! I tried Dave's "yardstick" technique & determined that I had enough clearance to upgrade to 185's and still have 11-12mm from tire to fender lip. I test-fitted a 185/65/15 on the rear driver's side and guess what: math works. In fact, because the tire is shorter there is actually more clearance than I anticipated; just over 1/2".
I'll take it out tonight and lean it into a few corners to see if I hear anything strange or see any rubbing on the sidewall. The tires, BTW, are Bridgestone Potenza RE950's. So far they seem swell. Mark |
