Manifold Pressure Control Sensor
I'm having intermittent problems accelerating, and I've been told the problem is my MPC sensor. Is this a common problem?
Old 02-09-2007, 04:22 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Bucking? thats usually the TPS on the throttle body so try unplugging it to see if it clears up.
The MPS controls the AFR via manifold vacuum, so if you have tons of vacuum leaks due to old hoses, seals etc the AFR can be off.
The vacuum advance plate inside the dizzy could be sticking too.
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 02-09-2007, 08:05 PM
Bucking indeed, but only occasionally. Thanks for your advice; I'll check those things as well.
Old 02-10-2007, 06:52 AM
