Felix's Avatar
(My modern 914 project) "neo914-6"
More info here
Felix
1974 914 250hp 2.7tt Audi conversion, neo914-6 concept
1990 300CE, 217hp AMG 3 piece wheels
1988 300TE, 260hp RENNTech 3.6L
1990 300E, 185hp stock
Old 11-16-2005, 08:05 PM
BURN-BROS's Avatar
Outstanding! It retains all the character of the original...I like!
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-17-2005, 05:54 AM
Felix's Avatar
Thanks Aaron,
That's the plan along with modernizing it!
Felix
Old 11-30-2005, 06:31 AM
Felix's Avatar
Pretty quiet membership here, I realize what I'm doing is hard to relate to but I plan to develop products that can be applied to a "stock" 914.
Here's a front design I'm considering. It's on the bumper link but here it is since the 914club site is currently down...
Felix
Old 12-25-2005, 10:13 PM
BURN-BROS's Avatar
Nice. Are you using a design program like Alias?
Burnham Performance
Old 12-27-2005, 07:08 AM
speed_bluester's Avatar
What's that front hood scoop for? One of the things I like most abouts 14's is that nice smooth sloping hood.
How about some vents for the engine?
Are the headlights going to be in the turn signal housings?
Too cool!!
Thanks, Gary
1970 914 2.0
Old 12-27-2005, 09:20 AM
Felix's Avatar
Aaron,
just old fashioned chalk and pencil. One of these days I'll get a digitizer tablet and buy Photoshop. Many designers use this or the company supplied program like Alias.
Thanks,
Felix
Old 12-27-2005, 09:34 AM
Felix's Avatar
Too cool!!
Gary,
I plan to fill in the top "locker" vents so I'm toying with the idea of welding in a Boxster tail light recess. Without the headlight doors the hood is virtually featureless. See the link in the first post for all the details...
Thanks!
Felix
Old 12-27-2005, 09:41 AM
BURN-BROS's Avatar
Great work! I've been eyeing a tablet for some time now . It lets you have quite a bit of freedom. I am on the tooling side of things, I just got finished machining a 1/4 scale model of an aftermarket bumper for the Ford Fusion. From Alias I would take your design and make patterns for molds...
Burnham Performance
Old 12-27-2005, 10:55 AM
Felix's Avatar
Could you take 3-d point scans from a full size plug? What material do you make the mold? That 1/4 scale must be pretty accurate!
Felix
Old 12-27-2005, 12:40 PM
BURN-BROS's Avatar
Digitizing anything is incredibly expensive. Its not the best starting point. I was quoted $3000.00 for 1/2 a scale model to be laser scanned with no clean up of the surfaces...ouch! I believe with Alias you create the 3D design and send an iges file that I would work on and mill what you needed. Its doable, but not cost effective.
The material for tooling can be a number of things depending on your need. Rennshape, MDF,or even styling/modeling clay can be used. The Auto industry has used clay covering a structure and have the entire car machined at 1 time. That way they can make freehand changes at their leisure.
MDF or Rennshape could be used to make an accurate pattern, then fiberglass to pull a mold off of it for either a fiberglass or themoformed plastic part. If it was steel, the file would be sent to a shop that would specializes in large stamping .
The 1/4 scale was only tough due to the extra long cutters and one being a .030 carbide endmill. Lots of little detail would have been missed without it.
Burnham Performance
Old 12-27-2005, 01:31 PM
Felix's Avatar
HID headlights are coming along...
Felix
Old 04-03-2006, 11:40 PM
Very cool headlight. I was thinking about something similar, but I thought I would need a glass lens because of the heat. Is this something that is available commercially?
Old 04-05-2006, 05:10 PM
Felix's Avatar
My first post here has a link to my project thread on 914club.com. There is a list of links to each sub-feature one of which is "HID Headlights in the signal pods". All the details are there.
It is perfect for my design since the stock pop-up headlights weren't appropriate for a modern design and the space gave way to radiators...
Felix
Old 04-05-2006, 05:58 PM
BURN-BROS's Avatar
Neat!
Burnham Performance
Old 04-05-2006, 06:15 PM
Felix's Avatar
Tony at TC Design has made great progress on mounting the drivetrain. He used the stock Boxster transmission mount bolted on a welded boxed section and cut some of the rear firewall. The front motor mounts are about 8" rear of the bar and he plans to use the stock front motor mount to reduce radial engine motion. The firewall will be replaced once fitment is complete. While the work is fantastic, it unfortunately will make it difficult to reproduce a simple conversion kit. If you ever need a spec track or street cage, TC Design is arguably the best in SF Bay Area.
Felix
Old 04-11-2006, 10:17 PM
Felix's Avatar
Here's the Boxster transmission...
Felix
Old 04-11-2006, 10:24 PM
David McLaughlin's Avatar
This is one of the most interesting projects I've seen. Thank you for sharing.
1970 914/6 RustoMod
2015 Mercedes E400
Old 04-12-2006, 05:46 AM
Felix's Avatar
Thanks David!
I saw a great episode of "Rides" last night with a "paint-off" of two top air-brush artists...
Felix
Old 04-15-2006, 12:28 AM
Felix's Avatar
drivetrain mounted, cooling lines bent, down pipes fabricated....
next, get it running!
Felix
Old 06-20-2006, 07:20 AM
