Post Front Oil Seal Replacement.
Well, during a road trip from Southern to Northern Calif. it looks like my front oil seal went (fan side). It ended up taking me 2 tanks of gas and 4 quarts of oil to get home!!!
So now the question of how to remove the thing the fan is attached to (I think its called the impeller hub). So I can replace the seal.
It looks like after removing the center bolt it should just pull out, but it doesn't seem to want to. Any help would be appreciated.
-Kevin
Old 06-28-2001, 12:54 AM
Eat-um-up's Avatar
Send a message via ICQ to Eat-um-up Send a message via AIM to Eat-um-up
Post
Im here in Bakersfield Calif. I just changed the seal in mine. if the part your asking about is what i think it is (a 'Y' shaped piece that the fan bolts to) try your local auto zone. The auto zone here allows free rental of parts. that thing dose slip off but you may need to get the puller from a parts store. I had to
Sweet Blue 72' 914
Check it out at
http://www.geocities.com/eat_um_up/914.html
Old 06-28-2001, 03:56 AM
roadtrp204's Avatar
Post
The fan hub fits on the crank with a taper, like a tie rod end, you will need a puller. It takes a little to pop it off, but goes on with very little effort.
Chris
75 914 2.0L
Old 06-28-2001, 06:27 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
Remove the 3 bolt that hold the fan to the hub. use a gear puller to remove the hub,The seal dan then be removed. How are your motor mounts? If they are worn now would be the time to replace them.Steve
Old 06-28-2001, 06:28 AM
914 Geek
Porsche Crest
Another way is to put some stout metal behind the fan hub, then screw the bolts back in and use those to pop it off. Just make sure that whatever "stout metal" you use distributes its load over a wide area, and doesn't concentrate it all in one spot.
I hear that bottle-opener "church keys" are good for this. I used some scrap steel that I had around.
--DD
Old 06-28-2001, 06:35 AM
Post
MAke sure when you re-install it to torque it to spec....I have seen many wasted type 4 crankshafts due to fans and hubs that work loose...I actually use loctite on the bolt..
Old 06-28-2001, 06:47 AM
Post
All right thanks guys... I made a big order here last night for all the parts I think I could use (engine mounts inc.)... Ill remember about using the loctite.
-Kevin
Old 06-28-2001, 12:32 PM
