Air flow meters
Does anyone know the differences between air flow meters on 914-4 and 912E?
The 912E part number is 0 280 201 006.
Do they have a different resposne or are they interchangeable?
What about vacuum limiter/deceleration valve?
They are both type 4 engines running L jetronic?
Matt
Old 04-16-2007, 06:24 PM
914 Geek
They both have a decel valve; not sure if the parts are identical or not. The response of the 912E AFM is different from that of the 1.8's meter, but you can swap some of them with varying results. (Note that not all 1.8s have the same number of pins in the AFM's electrical connector, I think the 75 has 7 and the 74 has 6 pins?)
--DD
Old 04-16-2007, 07:11 PM
