kirk4's Avatar
Post clutch spring
help.
I've rebuilt my pedal cluster and i need to ask one question. The clutch spring was broken on the cluster when i took it out so i'm not sure on the correct position. Looking at the picture from the PP rebuild kit I placed the spring the same as it shows. My question though is now the spring pulls the pedal towards the firewall with the cable not hooked up is this correct?
Old 07-08-2001, 01:49 PM
ejm914's Avatar
Post
It sure is. Correct free play is 15 to 20 mm. pulling the pedal towards you.
Old 07-08-2001, 02:01 PM
kirk4's Avatar
Post
thanx. I lost my clutch and when i checked the cable I noticed a broken clutch spring. If I'm lucking this may be my problem.
Old 07-08-2001, 05:50 PM
WOODPIE's Avatar
Post
As i understand it, the pedal spring's purpose in life is to maintain tension on the cable while the clutch is not depressed. A cable kept under constant, though minor, tension will last longer than one that is allowed to go slack and then is repeatedly snapped into tension.
Ed
Old 07-09-2001, 07:21 AM
914 Geek
Porsche Crest
...It also won't fall off the roller back on the transmission.
--DD
Old 07-09-2001, 08:42 AM
