Post cables and fuel line routes?
Under the battery tray along the body sheet metal (that holds the engine seal) there are three maybe four holes. I am not sure what lines go where. One large round hole AFT is for the engine lid drain. But the two oblong holes I believe are for fuel lines but WHERE DOES THE ACCLERATOR CABLE GO?
thanks-
Old 07-12-2001, 01:22 PM
914 Geek
Porsche Crest
The accelerator cable goes through a hole in the engine tin itself. The right-front piece should have a hole with a rubber grommet in it. The throttle cable goes through this, as does the stock oil temp sender wire.
--DD
Old 07-12-2001, 02:16 PM
Senior Member
Post
Hello
The long holes are for the fuellines but need the rubber grommet ( starting with 113# ) The larger round hole more forward is for the fuelpump wireloom. Down to the corner is a waterflush hole.
The throttle cable has also a strap that holds it to the ECU support.
Grüsse
Old 07-13-2001, 12:26 AM
