pilot seat
can any one help mi how to take off the pilot seat?
914 ,1972
thanks
Old 06-26-2007, 06:57 AM
914 Geek
There should be a loop-shaped handle at one front corner or the other that you pull up on to slide the seat forward. If the loop isn't there, feel for the broken-off end under the seat corners.
Pull up on the loop or push up on the broken-off end, and slide the seat as far forward as it will go. Then reach under the other corner of the seat and push up the metal tab that is in the middle of that side's slider. Push the seat forward and it will fall off the slider. Wear gloves, because there is usually a lot of gunk in there.
--DD
Old 06-26-2007, 07:19 AM
Dave thanks for the inf. the hook under the seat was broken.
thanks again.
Old 06-26-2007, 08:52 AM
