Hybrid cylinder Heads
I saw some watercooled heads for a Type 1 engine on the SambaVw forum. Are there any such heads available for the type 4 engine. This would make life alot easier for boost. These were not modified Wasserboxer heads but new castings made for aircooled barrels.
914 Geek
None that I know of.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Heres a picture of the head for a type one engine , The company is great plains aircraft but according to them they buy the heads from a company and put their engine kits together, I was just wondering did anyone know the Manufacture was so I could contact them directly.
Save the water for a Suby motor.....
Having aircooled heads on a boosted TIV didn't stop me from doing this yesterday... 2513cc,A/A intercooler, 7:1, 14 PSI boost, stock head castings.....Pump gas- for a daily driver... ![]() ![]() Thank god watercooled heads aren't available for the TIV.
Jake Raby Flat 6 Innovations and Aircooled Technology IMS Solution Inventor US Patents:8,992,089/ 9,416,697/ 9,687,974/ 9,909,369 '64 356C Outlaw,'76 912E,95’ 993,89’ 964 &'88 Carrera |
Hey Jake,
I was not questioning your ability to make horsepower, I was wondering if a little water would enhance your ability to make a little higher compression and a little more horsepower. You can take your gloves off, I am still planning to come to you to build my motor Mark Last edited by MarKoBrow; 08-10-2007 at 11:19 AM.. Reason: Mis spell |
No gloves were worn :-)
I just hate radiators :-) This engine wasn't just about HP- we put 11 solid hours of dyno time on it and it passed every check with better than typical results... Highest CHT recorded was 375F and that was in a 150 degree dyno cell with Georgia ambient temps at 103F yesterday. Its all in the combo.
When asking about the possibility of higher compression I am more concerned about throttle response, which is usually bad with with Medium boost and lower compression levels. Besides I just dislike unsightly radiators, I am sure the rads for these heads would not require so much room.
Mark |
To increase throttle response keep the intake plumbing compact and retain a sane throttle body size...
The intercooled Turbo in the graph had excellent throttle response on the dyno, more than likey due to it's intake characteristics and overall engine displacement.
4Cam shroud
JAKE RABY this is directed to you
On a different note what ever came of the 4cam fan shoud kit be offered a few years ago, I have since sold my 550A project but I am thinking hard about a 356A get back to me if you know anything about the folks that were selling them Mark Last edited by MarKoBrow; 09-06-2007 at 08:01 AM.. |
One unit for the pushrod 356 engine has been completed for a while.
I am currently developing a 4 cam shroud for the Type 1 and Type 4 engines and have just started the modeling processes. I expect development to take 18-20 months.
Can you send me a PM on how to get in touch with them or do you sell the one for the 356? I am assumming that it will fit my early 912 engine. Thank you in advance.
Go over to the www.spyderclub.com site and do a search for "Ibrahim".... He sells the unit.
Be prepared to spend SEVERAL thousand dollars on this enhancement!
