DSPTurtle's Avatar
Question High Idle
What would be causing my 74 1.8L from dropping back to idle? It seems to want to hold somewhere between 1,200 and 2,000 depending on where I push in the clutch to disengage the tranny. I can "drag" the idle down by slowly letting up on the clutch and it will hold the lower idle until I accelerate and slow down again.
Any advice???
Old 08-02-2001, 11:17 AM
bowlsby's Avatar
Post
Look for vacuum leaks, an open aux air valve or decel valve. Check injector seals, throttle body gasket and all vacuum hoses.
Old 08-02-2001, 11:30 AM
DSPTurtle's Avatar
Post
Could it be the Decel Valve? The car basically sat in a garage for the last 14 years. It is slow going but at least now I can drive it to and from the parts store
Thanks in advance!!!
Old 08-02-2001, 11:47 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Post
or a leaking oil filler cap gasket.
Geoff
76 914 2.0L
Old 08-02-2001, 12:13 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Porsche Crest
Vacc leaks on an L-jet car will often result in a car that idles very poorly, rather than one that idles too high. A malfunctioning Decel Valve might cause the symptoms you're describing.
The ignition timing could also give you these kinds of symptoms as well. Make sure the hoses are hooked up correctly (i.e., if you only have one vacuum fitting on the throttle body it goes to the retard fitting pointing back toward the distributor body, and the advance fitting does not get connected to anything). Make sure the diaphragm in the vacuum dashpot is not broken. Make sure that the points plate moves smoothly when you apply a vacuum to the retard fitting. And make sure that the points plate moves reasonably smoothly by hand as well.
--DD
Old 08-02-2001, 01:04 PM
mejulihn's Avatar
Post
Sounds like a tempermental decel valve to me.
Old 08-02-2001, 03:04 PM
Post
“…depending on where I push in the clutch…”
Clutch plate drag, or might the clutch and accl. cables be binding up?
Old 08-02-2001, 06:17 PM
