-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Sway bar bushing replacement (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/362024-sway-bar-bushing-replacement.html)
h.beard 08-14-2007 06:57 PM
Just bought my 1st 914. Solid '74 1.8 driver with a newly rebuilt stock engine. Needs some sorting on small items. Rear sway bar needs bushings replaced. Are these just put inside the one piece then pressed onto the ball using a c-clamp or the like.
TIA.....Howard in MD
Dave at Pelican Parts 08-14-2007 08:59 PM
Boil 'em in water to soften, then quickly get them into a vise to squeeze them in. You may need to help them get started with a screwdriver or other poking implement. I found that lots of made-up pseudo-German swear words helped. Well, helped me feel better--it didn't make the bushings any less of a PITA to install!!
--DD
Tobra 08-15-2007 08:18 AM
paint the drop links while the bushings are out and replace all of them while you are at it. Used a tie rod puller to press mine back on, used a quarter to protect the bushing.
