914 with 911 front end- Which strut inserts?
Have a question that I have not seen posted yet....
914 with a 1988 Carerra front end (Boge struts, bigger brakes and control arms with underbody sway bar. Popular upgrade for a 5 lug. Question: What inserts would be the correct pick for the front? 911 or 914? I am going with Koni adjutables and all the manufacturers Bilstein, Koni, Boge have different part numbers for the inserts for the 911 and 914 because of different valving. Anything else I should be aware of? Any problem using the new replacement 914 inserts in the Carerra/ Boge strut tubes? Are the tube dimensions the same. All I can see visually that is different is the crown nut securing the insert. Should I just order the 914 strut inserts for Boge tubes and go? |
If you are useing 911 strut housings I would think to be safe you would use 911 inserts. I am converting my 914 over to 911 struts/housings and I never gave it a thought to use 914 inserts. It might be possible but why risk it?
Wayne- please pickup the white phone!
I guess my question basically asks are the inserts dimensionally the same?
If they are then not a problem. If they are then need to change the game plan. 911 inserts have a different valving than the 914. The rebound is different. This may not be a problem as the 914 front end weight is lighter than that of a 911. This could even be an improvement. If the valving difference is not enough to worry about than will order what fits the tubes. I do know the insert retaining nuts (Crown nuts) are different on the outside. I am going to call Koni and Bilstein on this one. Wayne! Any input on this one? |
From Dave at TRE Motorsports.
Use the correct year inserts for the year/ model tubes. 911 inserts in 911 tubes! Any valving differences is minimal -if noticeable. That was easy...... |
| All times are GMT -8. The time now is 01:06 PM. |
