Jeff Hail's Avatar
914 with 911 front end- Which strut inserts?
Have a question that I have not seen posted yet....
914 with a 1988 Carerra front end (Boge struts, bigger brakes and control arms with underbody sway bar. Popular upgrade for a 5 lug.
Question:
What inserts would be the correct pick for the front? 911 or 914? I am going with Koni adjutables and all the manufacturers Bilstein, Koni, Boge have different part numbers for the inserts for the 911 and 914 because of different valving.
Anything else I should be aware of? Any problem using the new replacement 914 inserts in the Carerra/ Boge strut tubes? Are the tube dimensions the same. All I can see visually that is different is the crown nut securing the insert. Should I just order the 914 strut inserts for Boge tubes and go?
Jeff Hail
"All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible"
Old 08-26-2007, 10:58 PM
rfuerst911sc's Avatar
If you are useing 911 strut housings I would think to be safe you would use 911 inserts. I am converting my 914 over to 911 struts/housings and I never gave it a thought to use 914 inserts. It might be possible but why risk it?
Old 08-27-2007, 03:45 PM
Jeff Hail's Avatar
Wayne- please pickup the white phone!
I guess my question basically asks are the inserts dimensionally the same?
If they are then not a problem. If they are then need to change the game plan.
911 inserts have a different valving than the 914. The rebound is different. This may not be a problem as the 914 front end weight is lighter than that of a 911. This could even be an improvement. If the valving difference is not enough to worry about than will order what fits the tubes.
I do know the insert retaining nuts (Crown nuts) are different on the outside.
I am going to call Koni and Bilstein on this one.
Wayne! Any input on this one?
Jeff Hail
Old 08-27-2007, 04:13 PM
Jeff Hail's Avatar
From Dave at TRE Motorsports.
Use the correct year inserts for the year/ model tubes.
911 inserts in 911 tubes! Any valving differences is minimal -if noticeable.
That was easy......
Jeff Hail
Old 08-27-2007, 06:49 PM
