Finished stripping the old tar mats out of my '74 914. Some surface rust under them where rain/wash water got in, especially under seats and near pedal cluster, but not bad, no heavy pitting. Treated metal and sealed with POR-15, now I want to seal whole floor and add some soundproofing. What have people used successfully? I want something that doesn't end up gummy, and am thinking of brush-on bedliner material with rubber chunks in it (Hercules brand).
914 Geek
Herculiner? Uhhh... Just make sure not to get it anywhere you shouldn't.
http://www.explorerforum.com/forums/showthread.php?threadid=18595&pagenumber=1 --DD ------------------ Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
great link... I'll definitely avoid that one!
I've never used this liner material before, but hopefully it will serve both the sealing and sound deadening purposes. They list it as one of the uses on the can, so... |
Dave:
That was a great thread... I remember when it first came out. Id id not think it was still available. Thanks for bringing it back. ------------------
check out www.b-quiet.com liquid sound deadener. It's similar to a bedliner, but a little better for the purpose. You can brush it or roll it, and it always stays a little soft.
Hi - I just finished the job you are about to start. I used a spray on bed liner from the local auto parts store. About $7 a can, took 3 cans. It sealed real well and looks nice and finished. I do not notice any difference in sound dampening. It is a good watertight interior seal though.
------------------ Mark Howard '88 Carrera '62 356/B '75 914 1.8 resto |
for some sound proofing a cheap method is carpet padding. thats what i did.. low $$$ and did the whole interior at once. ive been told that there is a new spray on insolator for cars that will virtually make it sound proof.
http://www.geocities.com/eat_um_up/PICTURES.html |
...but the problem with carpet padding of any kind is that it absorbs water and hold it in place to do its number on your floor pans...
Thought the point was to avoid that sort of thing. |
Per the outstanding web page at:
http://www.914fan.com/ "Original replacements can be found from 1-800-WURTHUS. The sheets are 22" X 11" and there are 6 to a package for @40.00/pack + Freight. I takes two packages to do the entire floor. " Good Luck |
IN thinking about it, there may be a couple of other good products to use:
*Bituthene 3000/4000 sheet waterproofing. They are self adhering and bond tenaciously. They are inorganic and of course...waterproof. Ice and Watershield or similar products may be good as well. Get them at roofing supply places. *Dynamat |
Try POR-15. I used it on my Jeep and am very impressed. It won't scratch off, drys solid but flexable (is there such a thing) and is very expensive. But you will never ever have to worry about rust again.
