-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Do I have to bench bleed the M/C? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3742-do-i-have-bench-bleed-m-c.html)
ShawnO 08-20-2001 08:09 AM
I installed a 19 MM master cylinder a few months ago and now it's time to get everything working. I've read in a few places the the M/C needs to be bench bled.
Do you guys think I need to take the M/C back out and bench bleed it or should I just press the pedal real slow to ease the fluid into it from the reservoir?
That M/C was a real pain to install, I'd hate to have to yank it back out. http://www.pelicanparts.com/support/smileys/sad2.gif
ShawnO
[This message has been edited by ShawnO (edited 08-20-2001).]
Dave at Pelican Parts 08-20-2001 08:54 AM
You bench bleed it because it's a pain to bleed once it's in. Since it's a pain to install (again), just bleed it normally. A pressure bleeder may make it easier--I'm not sure.
Be prepared to go through at least a full quart of brake fluid. I'd have at least two quarts on hand.
--DD
