Still looking for my project car. Just went and looked at one. The best so far.
Battery tray is toast. The suspension mount is fine. But the rust/acid coming down from the battery has damaged the floor pan right under the battery. The spot that has that cone drain deal. Not gone, but damaged. Floor Pans great. Both trunks great. Behind seats are fine. No flex in the body with 200 person sitting in seat. One of the light buckets has a little seam rust, but still intact. Only rust, coming from the battery tray problems. Passenger rocker panel has rust. Mostly surface. Can that piece of the floor pan be cut out and replaced. This car will be 100% disassembled. Couldn't find a picture to show the spot on the pan ? Is there some where with jpegs for me to use for a better description ? TIA for your help. ------------------ Cary Kutter 77 Euro Carrera w/3.2 PCA Region - Big Sky [This message has been edited by cary (edited 08-23-2001).] |
Right Side Engine Shelf
B-501-214-90 $195.00 Its in Pelicans parts dept. |
