-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Finally My 1.7 build (HELP) (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/380803-finally-my-1-7-build-help.html)
troycom 12-04-2007 05:08 PM
I am finally getting ready to build my 73 carb'ed 914 YAY for me.Been waiting 20 years..
Im using the original 1.7 case..
I have a set of new 104 pistons and juggs..
I have a stock 2.0 crank and rods..
A new set of empi dual carbs..
I am going to port and polish the original 1.7 heads and have them flycut
to fit the 104 juggs..
Does anyone have an opinion on this good or bad feel free to set me straight
Troy
Dave at Pelican Parts 12-04-2007 06:16 PM
Current theory says that bores that large are not required for anything short of... Well, bragging rights! ;) There are also quite a few people who feel that going larger than 96es without spending $$$$$ for nikasil-plated aluminum cylinders is a waste of money.
96x78 or so is a very popular engine these days (look around for "2270"). With a good configuration, some of those engines are pushing 200 HP on pump gas. Evidently with a very nice torque curve and daily-driver type reliability.
It ain't cheap, though!
Spend a while reading up on places like the "Type 4um" over at http://www.shoptalkforums.com . Look through http://www.aircooledtechnology.com as well, but hold onto your wallet! ;)
--DD
troycom 12-05-2007 06:47 AM
Thanks for your reply,My wife bought me all these parts minus the crank and rods.
I guess my big question is, will all these parts run together in harmony or will I have clearance issues or case issues..
Thx again
Troy
hardflex 12-05-2007 07:59 AM
Wow, pretty cool wife :-) See if you can talk her into a set of nikkies to make it last!
I am pretty sure you'll have to bore the case and heads to allow for the larger cyls, but the rest of the stuff should work with no clearancing.
If you're going carbs, you might put in a carb cam to make it work a little better, especially with the 1.7 heads. I would think you need the valves open longer to move stuff in and out of the cylinders.
troycom 12-05-2007 09:19 AM
Sorry I didnt state this in the initial post..
I have a 00-152 new webcam and lifters I stole off Ebay for a song.
.423 lift .270 duration.
Also Im told I should use the original rocker configuration.
And yes my wife Rocks..
Thx Gang
I appreciate all the input.
PS.. I just finished building her a 78 spider convertable 160 bhp
spoke 12-19-2007 09:58 PM
I never thought of tricking out my wife's car so she'd let me trick out mine. Nice move.
Spoke
troycom 12-20-2007 07:23 AM
Thats the easiest way to get what I want, is to do it for her first:D
hers is done so now soon as the weather gets a little warmer my 914 will be built..
